I am preparing the plumbing for a two pipe wall mounted faucet.
The faucet is to be mounted onto male threaded pipe fittings.
The male threaded pipe protrudes partially out of the backing frame (board/blocking).
The pipes need to hold water under pressure until the wall is finished and the faucet mounted.
How do I install the rough-in and pressurize the lines before the faucet is installed?
- I looked for threaded caps and as of now they do not exist.
Are there such fittings? Is there another fitting I am unaware of?
- If I stub out the pipe with the intention of adding the male threaded ends I do not have room inside the mounting board to solder on the male threaded fittings.
- Do I need to install the faucet temporarily to hold water? That can be an option in this case since the faucet frame protrudes from the wall and wall board can be done above and below with the faucet in place. I am so used to having fixtures placed after the walls are done this does not feel right.
Thank you.
Thank you.
