Chefwong
The plan for the next renovation is a wall hung toilet. Been paying attention whenever I see one - as someone old me they all sag over time. Any pros or joes on board that can confirm ?
The two main reasons a wall hung toilet sags is because the wall behind the toilet is a plumbing chase and the bolts have to extend a long way to attach to the toilet causing them to bend and obese people.
That is referring to the old style 4 bolt carrier style wall hung? I'm pretty certain the OP is talking about the in wall tank style wall hung toilet which are rated to 600 or 800 pounds capacity with the carrier bolts have about an inch or two of length from the carrier to the finish nut.
Are you sure?
Have not dialed in all the specs, but I was leaning on the Geberit carrier.
Sure about what? that the OP is asking about 2 bolt carriers?
Yes.
Sure about the bolts only protruding 1-2 inches from the frame through the bowl.. well maybe about 3 inches. But nothing like the 24" long bolts I've seen 4 bolt toilets attached to without moving for 50yrs.
This may be a completely uninformed question but does it need to be installed against tile or is drywall fine? We weren't planning on tiling all the walls.Wall hung toilets shouldn't sag. If they do its because they aren't installed correctly or there is not the proper backing behind the wall.
We just replaced 2 on a project where the toilet was just a schoche shorter than the back of the carrier and it crushed through the tile. We replaced both with a slightly bigger toilet where the bottom of the toilet rests against the tile which rests against the carrier.
Its important that the carrier be 100% flush with the rough wall so that the drywall/tile backer makes full contact so that the toilet has no room to move inwards. Selecting the correct carrier with the legs that infill that space near the drain is key.
