Wall Hung Toilet Behind 8" CMU Wall
PlumbPlumb
Florida
Hello!
I have a wall hung toilet and an 8" CMU wall. Behind the CMU wall is a utility chase, so I have plenty of room.
Are there wall hung toilet carriers that can be used in this situation? I'm trying to use Zurn Z1202-N4-XH carrier but the cutsheets don't show how long the threaded bolts are.
Any suggestions?
Thank you!
the typical bolts on four bolt toilet carriers are just all thread rod, so you can provide any length you need.
The "P" dimension can handle good distance, if longer than 18" Aux. Support Assembly is required. You can get special drain coupling greater than 12" by special order.
You know for flushometer valves you need special up-sized water supply?
Yes sir. Water line is bigger and water pressure is fine as well.
