My Weil Mclain indirect tank has developed a leak at the boiler supply tank in port. It is back behind the insulation at the weld. This is my third tank in the last year and a half. The tank is supplied from a Weil Mclain gold CGI boiler. Strange thing is, this is the only spot that has developed a leak on all three tanks after about four months of use. The ports all have di-electric fittings and a ground strap for any potential grounding issues. Ph testing revealed no oddities. We are supplied with untreated well water. My tech is at a loss as to what the problem is. Thank you in advance for advice on what else might be occurring.
