MichaelAnglo
Please can someone help me with some advice?
I have a Watts softener with a 54" Vortech tank. About a year ago (yes, I know I procrastinate), when it was 4 years old, it spewed resin into my plumbing.
I bypassed the softener, and we contacted the plumbing company that installed it - but they have gone out of business.
I dilly-dallied, and then only about a month ago called a large local water softener company about it. They said I needed to replace the whole unit (it's now 5 years old but looks like new), for about $2,000 ... they said they don't know why it allowed the resin to escape and all I could do was replace the whole unit.
I was thinking that there is no way I can afford a new system every 4 or 5 years.
On Monday I did a search and found out how to check the distribution pipe and filter basket, as a source of failure. So tonight I pulled out the resin tank, removed the valve from the top .. and emptied the resin into two 5-gallon pails. I tried to remove the distribution pipe and then noticed I it is a Vortech unit. I can't pull out the distribution pipe (but didn't try tooo hard).
This is where I need help, please.
What should I do?
What could have caused the resin to get into in my pipes (a lot of it, it blocked washer filter and most of the faucet aerator filters)?
Would high water pressure cause this?
Should I try force the distribution pipe out of the Vortech unit?
Do I need a new Vortech tank, or can I use a standard tank?
Can I use a standard distribution pipe and filter basket in rhe current tank if I pull out the Vortech unit?
Why didn't the local softener folks even look for a cause of the failure?
Any help or guidance will be appreciated.
What should I do?
