diyguy0864
I have read a number of forums on check valve failures (which seems to sort of fit what is going on) but I am not entirely convinced which check valve may be going bad (yes... I have learned that it may be wise to remove the horizontal check valve near my pressure tank).
For info, my well is 85' down with a submersible pump. I recently replaced my pressure tank, switch, and horizontal check valve).
When the pump turns on, it pressurizes to 60psi, pump shuts off and the psi drops immediately to 50psi. If water is running, the psi drops to 40 before the pump turns back on and the process repeats. The strange thing is that with the pump off / water to the house shut off, the PSI in the tank did not drop. Videos below..
With water softener regenerating:
With softener running (but pressurizing looked different)
With water running, but shutting off faucet once pump turns on
Excited to hear the responses, thanks!
