7474
- Messages
- 43
- Reaction score
- 4
- Points
- 8
Per recommendations from this site, I recently replaced my 11 yo Stevens diaphragm pump with a Zoeller N57 with Superior Pump's vertical float. The float is actually manufactured by SJE Rhombus and has their tag with the Vertical Master name and part number and SJE's contact info. Superior's switch was about 1/2 price of what I found.
Is there a method to increase the on-time with a vertical master float switch? I thought I read somewhere here about modifying the rod to increase the run time. Or, does SJE make a longer rod for this purpose.
I have the float set to turn on right at the bottom of the drain tile inlet to the pump which is about 12" from the bottom of the pit. So, it still leaves about 5+" of water in the off position.
Today it ran for 10 seconds and was off for 70s throughout a storm.
Thanks for the continued assistance.
