Venting - toilet then shower then vent
JAMS
I'm trying to work a waste line around a beam/joists and my current solution: toilet (3" line), then shower (2"), then vent (2"). I can change the order to: toilet, vent, shower. Will either work with the IPC?
The vent goes vertical right after the wye and if needed, I may be able to make the vent line 3".
JAMS
Thanks hj, that's what I was thinking, but could not be sure.
Would swapping the vent and tub line locations make a difference?
JAMS
Thanks again. Would this layout work? The tub now has its own vent that comes before the main waste line. The two vent lines will join up when they go vertical
