Johnpstucky4ksu
Hello, I was wondering if someone could give me someone help on venting a plumbing stack for a very small living space I am putting in a shed. I've added an overhead plan and sketch drawing. I also have a few physical pictures I can add if its helpful. Basically its 1 toilet (3 inch), 1 sink (2 inch) and 1 shower (2 inch) in a bathroom. Then 1 sink (2 inch), 1 washing machine drain (2 inch) and 1 floor drain (2 inch) outside the bathroom. The main pipe is 3 inch.
Questions I have:
1. Which connections need a vent attached?
2. May I run 2 separate vent pipes 1 from the bathroom and 1 from the sink/washing machine on the other?
3. If I do run two separate vent pipes is 2 inch an acceptable size for each vent?
4. Is the vent required to run out of the roof or can it be ran out of the sidewall?
4. Any other thoughts or recommendations?
Thank you for your help!
Questions I have:
