poky1234
Hello,
I need some advice on venting a toilet. I have 2 toilets connecting into the main 4 inch drain. One is within 5 feet of the 3 inch vent stack which I believe is ok.
The other is 16 feet from the 3 inch vent stack. I have a 2 inch branch drain connecting into the 3 inch vertical drain of this toilet. The 3 sinks on the 2 inch drain line are all individually dry vented. Could the closest sink on the 2 inch branch drain serve as a wet vent for this toilet? If the plan is ok, would the 2 inch branch drain connecting to the 3 inch vertical drain connect with a wye or a sanitee?
I'm in Ontario , Canada.
Thanks for help.
Thanks for help.
