Radio Flyer
I'm installing a basement bathroom with a Saniflo macerating toilet. My main drainage line is 3" PVC running horizontally in the basement. The line is stack vented, continuing to the roof on the upstream side.
I plan to connect the 3/4" pumped waste outlet on the toilet into the 3" horizontal drainage stack with 3/4" pressure PVC and a wye. This will be several feet upstream from where the upper floor bathroom drainage enters the stack. No other fixtures enter the drainage stack upstream from this point.
My question is about where to connect the combined vents for the toilet pump, sink, and shower. Since the main stack is vented and no other fixtures drain upstream of the new bathroom, can I connect the vent into that main 3" line upstream of where I connect the drainage? If so, how far upstream should the vent be from where the drainage enters? And the vent should connect at the top of the 3" line, right?
In other words, can I connect the drainage near the left side of this photo and the vent somewhere on the right side?
Thanks for any help and advice!
