CallmeJake
Hi,
I am attempting to install a full bath on the second floor above a half bath. I think I have a plan, but not sure it if it works. The project is in Michigan near Ann Arbor.
I have attached a couple of sketches, still trying to get my head around isometric drawings. The non-iso drawing showing a "y" with a leg pointing down is actually supposed to coming out toward you.
The first question I have is around sharing the drain for the first and second floor WC. My understanding is a fixture cannot drain into a toilet vent. To avoid doing that, I was thinking about wet venting the first floor bathroom toilet through the lav and up through the roof. Does that work?
The second question is around the second floor bathroom. The WC and tub are back to back with only about 23” between drain centers and the stack being about center of the two. My plan was to use 3” sanitary tee with a 2” side inlet. Then into the 2” inlet I would ‘y’ the tub and lav drain. Out of the top of the tee I need to bush to 2” and immediately run two vent 90s to get into a wall to get up to the roof. Is the side inlet sanitary tee the right fitting for this? Is there a problem with the two vent 90s to offset the stack?
Is there a smarter way to do all of this?
Appreciate the help.
