Hi,
I am making a small closed gravity feed system to supply a utility sink.
I have a 55 gallon plastic drum with 2 bung closures.
The plan is to mount the tank on its side. The lower bung will have a spigot that runs the supply line to the sink. The upper bung will have a length of garden hose running down with a quick connect fitting. I will use this to refill the tank from a garden hose. This will allow me to fill the tank without having to get out a ladder as the tank will be 6ft or so above the ground.
I know that I need some sort of air inlet to let air out of the tank as it fills and into the tank as it drains.
I want something that will not allows insects into the tank. I found micromembrane vents that can be inserted in the 3/4 knock out on a drum bung. I am wondering if I could use one of these in a 3/4 hole on the side of the tank that faces up?
what other options would you suggest ?
Thanks for your help!
