Paul Blakely
In the attached photo of venting a double vanity, I see at least one mistake: I should have used a tee instead of a wye where the two vents join to go vertical. And I've also seen a more efficient way of doing this: a double wye from the vent stack at the level of the two drain outlets instead of connecting to the vertical vent 31" from the floor.
My question is: will this work the way I've done it, or should I bite the bullet and modify this before the sheetrock goes in?
Thanks.
Thanks.
