Vent Spacing
Thomas K
Opelika, al
Hi! I am planning stackable washer/dryer install, with 41" aluminum sheet vent going from (1) 90 degree coupling on dryer pipe to Dryer Jack mounted on roof. One thing I didn't think about is there is a PVC plumbing vent exiting the roof about 1 1/2' from where I plan to install Dryer Jack (or have it installed.)
Is it okay by code for vents to be this close? I am tearing my hair out wondering whether I've run into a snag I won't be able to fix. If I can't, I'll have to come up with another plan.
Thanks for any replies!
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Dryer vents must have a flap damper to prevent backdraft.
Code only cares to have vents distanced by three feet if there is an air intake.
So, as long as you have the proper spring loaded backdraft dryer vent.
Roof vents designed for dryers are notoriously problematic for cleaning lint accumulation out of the dryer vent pipe over the years.
Thomas K
Opelika, al
I'm going to use Dryer Jack in photo, made by InOvate products, because it's engineered for almost no airflow restriction and designed to be easy to clean.
Thomas K
Opelika, al
I don't know about this vent, but I have seen house wrens pick particular places to nest, like the back of your propane grill.
Thomas K
Opelika, al
Washer/dryer will be behind wall marked with X. I will either have a 45" vent exiting at roof dryer jack, or I will have to cut a hole in the brick wall, approximate location marked in photo, and run a flexible aluminum duct down to floor at 45 degree angle. Dryer duct would be drilled through bottom of interior wall shown in photo. If a roof vent will suffice, please tell me, as I will be able to reach over top of dryer and AC-foil-tape aluminum Snap-lock pipe to vent. I have to make a decision on this, and I need to make the right one.
I am really needing advice on this one, guys, and will listen to your comments.
