Before I get down to business wanted to say thank you in-advance for your time and suggestions. Your responses are very much appreciated. Also, wanted to dive on my sword for making a bad rookie mistake in laying out this vanity and cue some well deserved laughter from the group. Here's my issue:
We picked out the vanity illustrated below and neglected to refer to the rough-in specs for the drain.
As luck would have it, the wall inlet for the wast line falls 16" above the floor. Just high enough to be cut into the back of the vanity, but too low for us to install the P-Trap without butchering the cabinet:
Here are the vanity specs - the ones I should have referred to before closing the walls:
My idea for a solution here is to install the P-Trap within the "General Roughing-In Area" depicted in the specs, run the horizontal line to a Sanitary Tee, (air-gap 4" above the trap) and back around to the wall inlet. Below is a picture of what I came up with:
I think this is the proper way to do this without destroying the $1,500 vanity cabinet.
1. Please opine as to the reasonableness of my solution.
2. Sink tailpiece is 1-1/4. Was going to adapt to 2" at the J-Bend and continue with 2" waste lines.
3. I think the Air Vents are 1-1/2". Will adapt as necessary.
Thanks again for your opinions.
