WellAdjusted
Hello,
I am installing a PEX manifold system and have a question about making a series of 90 turns.
I have several lines that need to make a 90 turn relatively soon after exiting the manifold in a relatively tight space. One option I’m considering is using one of the metal stubout bend support straps together with the plastic bend supports designed to fit into it, as in the attached photo.
My question is if it’s OK to use the strapping and bend support like this (to make a turn early in the run, rather than at the end)—my assumption is that it is, but I thought I would double check before doing anything that would be a pain to undo.
