Using Oatey EPOXY PUTTY Still Leaking
JoeD
Using Oatey EPOXY PUTTY to stop a very small drip in my baseboard
heating:
1. Started by really cleaning copper pipe
2. Used about 3/4 of the Epoxy Tube
3. After a day I still have a drip much much smaller
4. Found the drip used about 1/4 of the Epoxy Tube
5. After a day I still have a drip much much much smaller
6. Found the Drip used about 1/4 of the Epoxy Tube
7. After a day I still have Some water not a drip
8. By now I have a large amount of Epoxy
and the DRIP is Slowing down?????
I Need HELP with How to apply the Exopy.
Should I Keep using the EXOPY on this small leak.
The leak is so small I feel I should beable to WIN.
I don't want to put in new copper until the Spring
it's the lower loop and it's relay Cool and I just wanted the Epoxy to hold
for a few months till I can fix it right.
Thanks
JoeD
epoxy
Are you removing the pressure from the pipe before you apply the epoxy and while it hardens? If not it will always force a way through before the epoxy seals.
Dubldare
Plumber/Gasfitter
MN/ND
:eek:
Wow.
Sometimes you just have to bite the bullet and fix it correctly, even in the winter.
JoeD
dubldare said:
:eek:
Wow.
You are RIGHT - It's all fixed - Thanks
