Using geo with existing heat pump
Vinoth
Pittsburgh
I have a house under construction and just decided to use electric heat pump so that I can run it with solar.
I just found out about geo. Can the electric heat pump be used for geo ? I would like to not waste $2000 worth of electric heat pump.
Can geo power some appliances at home apart from heat and AC ? Please advise .
Dana
In the trades
Even at twice the efficiency it's unlikely that a geo system would ever "pay off" over a minimum-legal efficiency air source heat pump that's already on site and installed (or about to be installed, with the ducts already in place.) Indeed, installing enough PV solar to cover the entire heating bill with the existing heat pump is probably cheaper than replacing it with an adequate geo system.
Abenr
Florida
Yes. As long as it can provide hot water, it can be used for floor heating. The only prerequisite is that the power of the water heater is large enough.
