Using an abandoned water heater vent for my plumbing stack
Hyrax123
Salem, NJ
I'm installing a mother-in-law suite in a basement. We can't tie into the main vent stack (we can't connect it high enough up). So the current plans were to find a run all the way up the third-floor. This is… well, it's a long way from the basement to the past the 3rd floor.
I had a gas water heater with a 4" possibly aluminum stack that runs up to and out chimney. It's no longer used.
I'll be tying in three sinks (kitchen, bathroom, and utility sink), a bathtub, a washer, a tub, a toilet, and a dishwasher.
Can I use that stack for venting the plumbing?
WorthFlorida
Solutions
Orlando, Florida
If it is a abandoned steel chimney of sorts? Are all of these fixtures in the basement?
I assume your talking about dropping dwv pipe thru the inside of the abandoned water heater vent. only problem with that is code requires support on each floor. but I think if you support it with a risor clamp at basement and support it again at attic youll be ok but . I couldnt argue that its legal.
Hyrax123
Salem, NJ
Yeah, I'm not sure how we'd get DWV pipe that long into the chimney -- but I think all-in-all that'll be easier than finding new routing from the basement up past a bunch of eaves, etc. We'll see what they think
JohnnyCom
Sebastopol, California
Or drill a small hole near the bottom of the first pipe and attach a paracord or other small rope to support the stack as you lower it section by section. Then remove the cord after the pipe is supported otherwise from below.
There's a good way! I wasent planning on going on roof , could be steep, poor condition, no idea what he wants to do up top, I would flash the vent where it passes to open air so water cant leak around it .
Personaly I avoid roofs most of time , especialy if he is going to have a roofer on site. 2 or 3 stories up , Id be discussing it with owner because a steep roof and 3 story be talking about more money.
