uscpsycho
That seems like a plausible assumption. But the external amp is getting its audio signal from the AVR so you'd think it's also filtered. If the AVR has better filtering it's possible the filtering is only done for its own speaker outputs and the any pre-outs (which feed the external amp) aren't filtered. Actually, that might make sense because you want the audio to an external amp to be unaltered so maybe it's unfiltered too.I find that odd too. My only guess is that the AVR has better isolation/filtering than the external amp(s) and so avoids the problem? You could try the cheater on the external amp to see if that make the problem go away. Then if an external amp is available with a 2 prong plug, that would be a work-around.
I'll try putting the cheater on the amp and see what happens. That's a great idea. If it works replacing it with a two-prong amp seems easy enough.
Electrically, the same as the extension cord, but with in wall wiring. Add a new receptacle next to the existing #2, but bring power to it from the circuit that supplying receptacle #1. [Bringing power directly from the box supplying receptacle #1 would be safest, but I would think that any box on that circuit would work. Although perhaps it's best to be take the safer route.]
This is easy in theory but involves a lot of work so not exactly easy to do. I proposed this to the handyman and he gets it but doesn't want to do it. I think partly because he'd be putting holes in walls that he spent most of yesterday patching.
I've got a multimeter that confuses the hell out of me. If you can tell me how to test this I will.I would be curious what the AC voltage is between the ground pins on the outlets in question.
I would also be interested in the megohms between the ground pin on each unplugged plug and its neutral (the wider blade).
2) GFCI will not isolate the ground any kind of AC hum or interference. It only monitors that the current flow between the hot and neutral is less than 5 milliamp difference. Above that it trips.
I know it's hard to read from the other posts but the GFCI isn't here to help with the hum. The cheater plug does the job perfectly. The GFCI adapter joined this party to live between the existing outlet and the cheater plug to reduce some of the risk that was introduced by using the cheater plug. I was hoping the GFCI adapter was enough to put this matter to rest but I was advised that permanently eliminating ground from the projector is not a good solution.
3) It's hard to read from other posts but it appears that one outlet is on one phase and the other is on the other phase of a two phase system and there is a ground potential difference. Place a voltmeter from the hot to the neutral and from the hot to the ground. Check the voltages. Then do the same with the other outlet. You want the readings to be the same.
It was suggested that the two outlets might be on different phases but I have not confirmed. Is your suggestion about using a voltmeter a way to figure out if they are on the same phase (instead of the counting technique suggested above) or is this an additional troubleshooting test? Can I do this with my multimeter? If so please explain how.
Have you tried just changing the Ethernet cable?
Are any of the items a simple, 2-prong, unpolarized plug? If they are, try flipping the plug around.
I have tried two different ethernet cables one shielded and one unshielded.
I know some of the 2-prong plugs are unpolarized. I will try flipping them but this is going to be a bigger headache than you imagine! I've got several power strips with lots of plugs and it's like Tetris getting everything to fit, so flipping these guys is gonna be quite the operation!
