Use vent pipe as a drain for 2nd Floor Laundry
Rsopenroad
Cleveland, Ohio
I have an easily accessible 2” vertical vent pipe from basement thru the 2nd floor attic; where, the 1st floor fixtures’ vent pipes connect into one vent pipe above and thru the roof. Target location for the 2nd floor laundry is an existing closet that is built partially into the attached garage’s roof line. We only need an in-wall laundry hookup. And, the back side of the interior wall has open access, with approx 10ft clear route to the 2” vent pipe from the basement.
Can I drain from the laundry p-trap into the 2” vertical vent pipe?
John Gayewski
Iowa
Well then you have partial good news. You can use this pipe to tie the laundry vent into. Meaning you don't need a roof penetration, but you will have to run a seperate drain as Wayne suggests.
wwhitney
Berkeley, CA
Thanks. But, there’s no chase in the finished walls to run a drain pipe from attic to basement.
Well, the new drain would only have to run from the laundry room to the basement.
Regardless, you can't use that vent as a drain. You either need to find a different drain on the 2nd floor to tie into (which can't be in the middle of a bathroom group that is using wet venting), or open the first floor finished walls to add the drain from the laundry room to the basement.
Cheers, Wayne
Tuttles Revenge
If you used the vent for a drain, How would you vent the fixtures that currently use that vent for venting?
