The indirect I have has a quite deep well for the temperature sensor to the boiler control. There's a spring that came with it to help grip and hold the sensor (I think), but the actual well seems to be stepped, and you can actually push the sensor in 3-4" further into that smaller diameter area than the spring clip will pass.
The installation manual doesn't really describe the proper insertion of the temperature sensor. Flopping around without direct, intimate contact would seem to be moderately inaccurate.
Right now, while the spring clip helps to hold the cable, the actual sensor is pushed to the bottom of the sensing well, but there's no conductive grease in there.
Does adding some conductive grease make a difference? Is it worthwhile? Or, is having the spring clamp holding the sensor verses the wire, where it isn't anywhere near as deep in the well what they had in mind?
