Dan B
Yes. Last nightHave you backlighted your tank and watched a backwash?
Normally no check valve needed. Just set the timers to insure they don't overlap.Brings in another question I was holding off. I have a water softener tank following the neutralizer. Softener was installed before the neutralizer. I didn't want to thread another 60ft of PVC for the neutralizer. Was planning on Teeing the two drains together. Read somewhere this could lead to backflow into the brine tank during neutralizer backwash. My plan was to install a swing check valve in the softener drain branch. Thoughts?
I think the question was asked of SShawYes. Last night
Unless your water is very cold, the charts located at the links provided earlier, indicate the BW rate for a 13"AN tank is 9 - 10.1 gpma 13x54 2.5 cu-ft acid neutralizer installed by an experienced local dealer. Their specs say the backwash requirement for my system is 7 gpm.
That is the discussion, and I think it is a worthwhile one.. http://www.waterchemistry.com/products/resin_media/calcite_2386.pdf calls for 35% bed expansion. Maybe that is much more than necessary. But 10% seems low. I am not a pro. Dan's has maybe 3%. (estimated about 1/36).
I don't know. Take the old one to a big hardware store to see if they have a match until you find out.Little embarrassed by this one...Does anyone know where I can pick up the o ring for the DLFC for a 5800? Pinched it....Seepage. Amateur..
Since the pressure did not climb during the backwash that suggests your pump can only provide 7.1 GPM at 40 PSI.The well pump cut in at 40 and held the pressure there throughtout the backwash...
Was that measured near the beginning of the BW cycle while the pressure tank was supplementing the pump flow rate, or near the end of the cycle?Measured 8.57 GPM!
Nice. Did you note the pressure gauge during this?
I think leaving this out would be fine. Two inch expansion still seems less than ideal, but it is a big improvement. This tells me that a 10 or even 12 gpm backwash would not be too much.
I very much doubt that the 1 inch option would make a bigger flow vs the 3/4 with no button. I would leave the button out.Pressure gauge held at 40. Only way to get more flow would be to replace the DLFC with the 1" option. Not out of the realm of possibilities.
I am having trouble reconciling that, because it is such a low bed expansion. There seem to be contradictions.The lower chart specifies the backwash flow rate needed for Calcium Carbonate is between 8 and 12 gpm per ft2.
Update on today's experiment. Removed the 7 GPM button and ran a backwash. Measured 8.57 GPM! Calcite rose little less than 2 inches. Backwash was cloudy. Took about 30minutes of backwash to clear that up. I'm thinking the initial rinse was not effective at the lower GPM. Thinking of leaving the button out. Opinions?
This is confusing. Pumps run on a curve so if before it held at 40 when delivering 7.1 GPM, how can it deliver more GPM and still hold at 40?Pressure gauge held at 40...
I expect the gauge did not read 4o when the 8.57 GPM and ~2 inch bed expansion occurred. Maybe 30. Maybe less. I think that is ok. GPM is GPM.This is confusing. Pumps run on a curve so if before it held at 40 when delivering 7.1 GPM, how can it deliver more GPM and still hold at 40?
What contradictions?There seem to be contradictions.
That among others.What contradictions?
Do you mean the amount of lift observed through the tank walls when backlit compared to that expected for the 35% bed expansion specified?
Do you seriously want to complain about retaining too many digits from a calculation? So rounding 8.5714285714285714285714285714286 to 8.57 bothers you -- you want 8.6 or 9 instead. I often retain 1 or 2 more digits than are actually significant on purpose, violating those "rules". I know the rules, and intentionally violate or stretch them. What if somebody wants to convert the number to liters per second?The 8.57 gpm stated for the BW flow rate seems very specific for an estimate or even a measurement of the amount of water that flowed into a bucket from the drain line in 60 seconds. I can understand stating 8.5 or maybe even 8.6, but 8.57 gallons?
LOL! Read my comment.Do you seriously want to complain about retaining too many significant digits from a calculation?
Do you think I quoted your post out of context?LOL! Read my comment.
I think it was 35 seconds to fill a 5 gallon bucket.I anticipate if a calculation was used to determine GPM, it will be because an alternate amount of time than 60 seconds was used to collect the sample to be measured.
I see your point about the use of the 7 gpm DLFC. I also note that whoever said this was appropriate should have checked that your pump could meet the backwash needs with the appropriate DLFC.Brings up another point......The prevailing wisdom is that a minimum of 8.5 GPM is needed for a 12 inch tank. I find it interesting that I was sold a 12" with a 5810 valve incorporating a 3/4" DLFC. Parts diagram shows largest washer possible for the 3/4" DLFC is 7 GPM. Needed is the 1" DLFC which has larger orifice and can handle washers up to 30 GPM. See the problem?
