Runekey_69
hi
i currently have 1 cubic foot of anion resin beads in my tannin filter after my water softener. it lasts about 100 gallons before i start to get yellow again.
And I recently lost water pressure about four times before i solved my pump problem.. causing red foamy discharge when the water pressure returned, so I know I damage the resin but by how much I don’t know.. this resin is only 3 months old.
I suppose I should’ve opened up the intake valves partially Then Put it in to backwash to get the air out before fully opening the bypass
i think i was getting about 250 gallons before yellowing before the damage. but i still got yellow when i went above 3.1 gpm soooo
I would like to increase my capacity by another cubic foot for two total cubic feet But I don’t know if I should replace the old resin or just add another foot with the old resin.
maybe I should make it 3 ft.³ and just add 2 ft.³ to the one old cubic foot that I have.
Does type one or type two resin matter too much can I mix them?
Here is a picture of my Water before treatment. Does this look about right to be getting 100 gallons out of a cube foot?
