Hello again plumbing pros,
I am slowly making progress on the basement bathroom and have a new puzzle for you. This is what is left of the 1.5" inch drain riser after removing the obsolete pipe from the old upstairs bathroom. In removing the old galvanized pipe, this portion got a bit mangled and is now loose in the floor.
I am converting to ABS for the upper portion of the new lavatory drain and was originally planning to use a Fernco shielded coupling. But now I'm wondering if it would be better to remove the remaining steel pipe and go direct to ABS using a donut. I can't quite tell what is holding the steel pipe (it doesn't seem to be threaded) and how I would remove what looks like cement without clogging the drain.
Please advise...and thanks as always!
