MaplesonD
Hey guys,
Here's my previous post where I asked about how to troubleshoot my problem with unsuccessful brine tank refill. At that point I was too focused on the float mechanism even though you correctly told me that had nothing to do with it. After manually putting water in the brine tank after each regeneration for a few weeks, I had a professional come out to look at it, being a bit intimidated to go further myself. He told me that the brine valve was "sticking" and would need to be rebuilt. I found a video about Brine Valve repairs and took the cover off to mess with the brine valve myself.
When I ran through the cycles to get to the brine refill, I watched the brine tank and brine valve and could see that initially, there is some refill until after just a second or two, it stops. I took a screw driver and pressed in on the brine valve (like they show at the beginning of the video) and I could hear flow and see that the brine tank was filling. It would only fill while I was actively pressing in on the brine valve.
Reach4 pointed me to this link of a post that matches my symptoms to a T, so it seems like I probably do need to replace the brine valve. The pro I had out here priced a valve repair kit at $180 (thats just the kit, labor presumably separate), but the first thing that popped up on a google was a brine valve for $21. I'm more inclined to tackle this myself now, but I want to make sure I get everything I need and have quality parts replacement, so I was hoping for input from you guys on sourcing the parts to replace the brine valve, or any pitfalls I should be aware of.
Thanks
Thanks
