Mark Christensen
My wife and I own a building that was built in 1929. An adventure doesn't quite describe it. I consider myself a 9/10 in terms of handyman skills. I ran into this last night though with a toilet I'm trying to replace. The bolts were completely rusted through and you can see there is some sort of flange that sits about 1/2" proud of the floor. Is this something I can wire brush and retrofit a flange collar into? Then core down some new bolts into the floor? I can't see any distinct "joints." I realize it's messy, but I'm hoping I don't have to remove or cut this flang out to put a collar flange in. I'm worried if I do do that, then the wax ring will sit too high for the toilet to mount correctly.
Flang opening at top is 5" ID, so I'm assuming it's about 4" ID once it gets into the drain.
