perion
I'm redoing some plumbing for a kitchen sink, and have a few miscellaneous questions.
- I've seen the terms "trap arm", "wall bend" and "wall tube" used to describe what I believe is the same part (i.e., the tubular pipe that connects to the J-Bend on one end and the ABS waste pipe at the other). Are these the same part?
In order to continue, I'll refer to the part I've described as the wall tube.
- There's a 2" ABS waste pipe in the wall, and I need to attach a 1/4 bend (90 degree) fitting to it. Can I use a standard 1/4 bend fitting, or is it best to use a long sweep one?
- The wall tube (which came with the P-Trap kit) has a beveled flange and a length of 7.5". I'd prefer one that's ~12", but haven't any luck finding one online. Does such a beast exist; if not, is there another way to do this without using a coupler?
Thanks ... and if you any questions about what I'm doing (I know I do), please feel free to ask.
aul
aul
