Under sink Tankless + water filter questions
Discussion in 'Tankless Water Heater Forum' started by MasterApprentice, Aug 15, 2019.
  1. MasterApprentice
    MasterApprentice New Member
    Feb 24, 2019
    Aurora, IL
    Hello;
    I am installing an under sink tankless heater for a kitchen remodel. The reason for the heater is that we have hot water running through a slab and it wastes a lot of water and heat just to get a stream warm enough to wash dishes, especially in the winter. My wife wants a water filter as well and I'm wondering what order I should connect everything up in the circuit.
    I am thinking I can cap the hot water line and run everything through the filter, but I'm not sure if this would limit me in some way I haven't thought of yet. In this case it from the cold water line I would go to the filter then split one line to hot water, which would then feed the faucet and dishwasher. This way all of the water would be filtered.
    Alternatively, I could just run the slab hot line to dishwasher (this water would never even be warm when going into the washer). It wouldn't be filtered, but then everything wouldn't be fed from the cold line.
    Any thoughts?
    Filter will likely be this: https://www.propurusa.com/Inline-Connect-FS10_p_219.html
    And Tankless heater will be this: https://www.homedepot.com/p/Stiebel...less-Electric-Water-Heater-DHC-10-2/203210886
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    With reasonable water pressure putting the filter up stream of everything shouldn't be a problem. With any tankless the less crud & minerals is better, since they tend to to develop lime and other deposits on the heating elements over time. (If you're on a well, a water softener may also be a good idea.)
    Be sure to install fat enough wiring to this beast. The minimum wiring sizes for the 9KW & 10KW versions is #8AWG, so don't even THINK about hooking it up to a #12 AWG circuit. The 10KW version needs a dedicated 40A/240VAC breaker, which is a large chunk of the total panel capacity for most houses. Make sure you're staying within the limits of the main panel too- you don't want the whole house to go dark occasionally when the dishwasher is filling.
  4. MasterApprentice
    Feb 24, 2019
    Aurora, IL
    I'm on city water, so no water softener. Having an 8AWG, 40A dedicated circuit installed next week after I tear out the old cabinets and such.
    I only have 100A service, but the biggest draw is a 25A 240 line for the central AC. Drier, main water heater, furnace and stove are all gas and if I calculated correctly the 40A line will put me at 89A total.
Similar Threads: Under sink
Tankless Water Heater Forum Tankless electric water heater under counter? Oct 25, 2018
Tankless Water Heater Forum Undersized NG tankless - supplement or replace? Apr 16, 2013
Tankless Water Heater Forum Understanding my tankless with recirc system Mar 22, 2012
Tankless Water Heater Forum Setting up a tankless water heater to a utility sink Mar 10, 2019
Tankless Water Heater Forum Point Of Use Tankless for Sink and Dishwasher Jan 4, 2018
