Mike6f
Normally nothing phases our disposer and drain, but cleaning out all the cupboards and pantry I went too far. The oldest of three opened bottles of Kyro syrup stalled the disposer, as did a bottle lid that fell in with a batch of produce. Those were easy fixes, fishing out the cap with chop sticks and resetting the thermal breaker, but what stopped everything and remains stopped up in the drain is the half a bag of uncooked rice that sure looked like it was going right down.
Nothing seems to touch uncooked rice, the trap was so jammed when I took it out I had to dig the rice out with a fork. and still almost no flow with the trap cleared.
I put the trap back in and ran a few inches of water into the sinks, dropped about half an inch in an hour. Repeated this a few times. Four passes of two types of Liquid Plumber, more water, hot water, cold water, bottle of the Eunique bio stuff, more water, and ran as much of a cheap 25' snake in with the trap half removed.
Other half of the bottle of bio stuff is in the system all of tonight, with another test in the morning, then the old ABS P trap is getting cut off and I give the snake a better angle and try it again.
Time for a pro, or am I doing something obviously wrong like too small of a snake (typical Home Depot 25' $25 snake), and what should I tell the drain guy on the phone to make sure he can fix it?
Thanks.
ABS trap has a leak on the drain side threaded connection, maybe a crack, hard to see, so I bought a tubular poly to replace it.
Thanks.
