Unable to run off outside water spigot
greatdeals_007
California
I have a red and blue dial on the PVC pipe that feeds the outdoor spigot however turning those off did not turn off the water. I had to go to the main water box to turn off the water.
what are the red and blue dials for then?
Treeman
Active Member
Michigan
Those Blue and Red valves look like they feed an underground sprinkler system (or other outdoor system) fed by the vertical pipe with the pressure regulator on it.
It is tough to see, but the hose spigot looks like it comes directly out of the wall and is NOT connected to the vertical pipe.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
It looks to me to be connected but I agree with the red and blue knobs feeding underground and the feed coming out from the house near the hose spigot.
greatdeals_007
California
could be but why a red and blue dial then? hot and cold?
I suspect you are joking, but if you are not, they were what was in the store, or the person wanted some way to associate one function with the red handle, and the other function with the blue. You could see the advantage in trying to explain to somebody how to do an operation if the handles are different colors.
Treeman
Active Member
Michigan
Upon closer inspection, you are absolutely correct!
LLigetfa
NW Ontario, Canada
Being frugal to a fault, I have hot and cold hose bibs but the knobs were both red so rather than buy a can of blue paint, I just took a wire brush to the cold knob, removing the red paint. If in my lifetime, I happen to get some blue paint, it is all prep'ed.
