Unable to remove Moen single arm handle
Bourds
New Jersey
I'm unable to figure out how to get this single arm shower handle off. I've popped the cap and removed the center screw but it will not budge. I've gone around it multiple times and I do not see any set screws. The trip plate says Moen but I haven't found any pictures online that resemble this particular handle. I have two showers each with the same handle and both have the same problem. Anyone have any ideas or know what model this is?
It pulls straight off. The cartridge is a Moen 1222 Posi-Temp.
You have the commercial version of the trims. I had the same trim at the hotel I stayed at this weekend.
If no set screw it pulls straight off tap it with wood block rock it back and forth , spray vinegar , limeaway in hole , or CLR get busy with it it'll come off. Set screw is always on the bottom you said you looked so that means there is no set screw all the 1222 valves I worked on had set screw. but mine were almost exclusively residential
If valve turns on by turning handle its a 1222 if handle pulls out to turn its a 1200 /1225 cartridge
Bourds
New Jersey
Thanks for all the suggestions. I worked on it for awhile with vinegar, even tried a hair drier (read that somewhere else) but in the end I snapped the cartridge. Had a fun time getting the remainder of the cartridge out but finally did (should have been replaced anyways). All set now!
All Fug Duck
Florida
This.
