I haven't been having much luck with my other questions so I will try a couple new ones.
I need to tie into some 14 year old Wirsbo PEX-a for a a fridge in my basement finish. If it matters this is a line coming off the manifold before the water softener but I don't have any extra ports on that part of the manifold. Given the PEX-A is 14 years old and has been exposed in the unfinished basement (no direct sun) all that time, will it still expand properly to take a T?
Also trying to figure out my basement shower p-trap. Plumbers put the 2" drain line under the concrete at a really inconvenient angle. To make the trap fit and line up with the shower receptor I have two options. Knock out some concrete to move the trap connection back about 3-4 inches so I can have about a 30 degree angle between the trap and the drain line; or extend the drain line past the shower drain and bring the trap in from the back side. This would give me about a 150 degree angle between the incoming drain line and the trap. Take a trap and swivel it all the way around until the inlet/tailpiece almost hits the crown and this is what I mean. I found one old post on here that said having this large change of direction in the trap is not a problem but the only ones who answered the question were not plumbers. I would rather not have to cut into the concrete if possible as there is a 3" waste line that runs right where I would be cutting/jack hammering.
Thanks for any help.
Regards! Dennis
Regards! Dennis
