Terry Love Help!
Two party shared well:
Pay for own pumped water.
Share property line well with two lines. One line existing neighbor and other to my Shop. Currently, the old arrangement was 50/50 share of energy, expense, maintenance, and replacement. Estimate neighbor usage based on 4 member family home on two acres with 10K sq. ft. green lawn and watering an extensive windbreak shelter belt, usage 80K to 100K gallons water. My one acre has a 4K sq. ft. work shop with a 1,000 gallon fresh water tank inside, a gravel packed 1/2 acre parking lot and Buffalo grass, usage 12K to 20K gallons water. Local Well Company bid $10,000 for dedicated well. I need a fair cost water and expense/maintenance/replacement of any well components. The Electric Cooperative Engineer suggested to install a personal analog electric meter to track the energy use and a plumber to install a water meter on each line. You explained well pump cycling in another article, my fresh water tank resolves the smaller amounts of water pump cycling on the well. I understand that you advise folks to share 50/50 on a well.
What would you do ?
What would you do ?
