hello all
I have a new house and the outdoor outlet is a standard WR 15a plug fed from an internal GFCI, I attempted to change the outdoor outlet to GFCI but neglected to switch the internal GFCI to have both feeds on the line side, when I installed the GFCI outside it came up and tested ok but about a week later I noticed it was tripped, the red light was blinking (hubbel) and there was a slight amount of black residue in the water tight enclosure.
I promptly removed the GFCI and inspected the wiring which all seemed fine as well as beyond the black material and the popped unable to reset state the GFCI was intact (no signs of melting or damage)
I replaced the outlet with the standard WR outlet again and now everything seems fine
From what I have read it seems what I did was redundant but wanted to know why people thought the outlet would have failed and if there is anything else I should be concerned with?
Thanks
Thanks
