Hi everyone,
I've been looking around for a twin tank control valve that does upflow regeneration, soft water brine tank refill, soft water regeneration, and which has no hard water bypass. Pretty sure that doesn't exist. (Please let me know if it does!)
So, I figured I'd see if I could rig something up. Here's my solution: 2x Fleck 5800 control valves, 2x check valves, and 4x normally-open solenoid valves.
Red is the normal raw water inlet.
Blue is the normal soft water outlet.
Green is for the crossover.
Grey vertical components are check valves that only allow flow in the upward direction.
White ball valves are solenoid valves, but I didn't have a good solenoid valve model.
All the pipes are the same in the model, but I'd use 1" for the main inlet/outlet and then switch to 3/4" where they split in two.
Under normal operation there should be no flow through the green pipes.
When the left tank is regenerating, the left two solenoid valves close. This blocks any water coming out of the tank (no hard water bypass) and also blocks raw water from entering the tank. Instead, treated water from the right tank provides water for regeneration/backwashing and for the house.
Now, if only I could find some cheap and reliable check and solenoid valves! Price is the only real downside I see, plus more (or just different) parts to break. It also definitely needs more space for plumbing, but it could be a lot more compact than what I modeled.
Any thoughts on this setup?
Oh, and I know there are a lot of potential issues with upflow regeneration (I'm not even sure I want it anymore), but let's save that debate for another thread if that's okay.
