I'm installing a Moen positemp valve. It has combo type fittings. You can either use IPS or solder copper piping. I'm going to solder copper to the supply sides. I'm not sure about the bath tub spout stub, however. The kit I purchased came with a screw on spout. I could pipe the stub in copper and then add a male threaded adapter at the end. I'm just worried that the solder joint at the elbow might give screwing on the tub spout. My other option was be to just go with galvanized pipe. I have read that it will eventually rust.
What are your thoughts? Should I have any concerns with the breaking the solder joint when screwing on the spout. I also have access to an oxy/act torch. I could braze on the elbow for a stronger fitting.
