My house is aprox 54 years old. Since I have had the house, (about 3 years) there has been a small leak coming from the shower/tub into the basement. The drain is not the source. Last August I replaced the packings and stems, etc in the pitchfork assembly. The leak is still occuring so I checked the packings,stems tonight and all is fine. I have an access panel behind the tub and it seems all connections are dry. I know where the leak is coming from..but not the sourece.
The water is coming from behind the caulking where the tile meets the tub. that horizontal surface, (under the handles/faucet)..it will run along the edige up to the front vertical surface of the tub (behind the caulking still) and find its way through the floor into the basement. I noticed this when I pullled the cauliking in one spot, and took a flashlight and looked in the 1/4 inch gap between the tub/tile and saw water dripping/seeping. I looked in the access panel and the part where the tub meets the tile backing (concrete type matieral in mesh) its wet right at that portion and the water will run along under the lip of the tub.
Tonight, I chipped away the tile around the hot, cold, and diverter valve..and removed the faucet and chipped tile away around the facuet pipe. All are dry I even removed some of the plaster around the shower head, and the 90 degree elbow is fine..all dry...I am stumped as to where this water is coming from.
Could the water be coming from the grout needing to be sealed or bad caulking along the edges/walls of the tub/shower? I know water can run in wierd paths..but I am stumped as to where this leak is coming from. I feel I have tried everything short of ripping out the entire wall..and in all honesty I dont think that is a smart idea, since it is dry around all the plumbing fittings.
Thanks in advance for the replies..I really could use some help
