ElLlamero
- Messages
- 3
- Reaction score
- 0
- Points
- 1
I'm in the middle of a shower-to-bathtub conversion for my master bath. I've picked out a few Hansgrohe fixtures, and even run them by Hansgrohe support to confirm they'll work together. However, when I was getting quotes from suppliers, I had one supplier say there was a major issue with my design, and that I should consult a plumber. Given this forum has been a great source of advice in the past, I thought I'd start here.
The concern was regarding my use of three water sources with two diverters. The person was concerned that I could experience a backflow issue due to negative water pressure. Overall I don't understand the concern, but perhaps someone here will have some experience with this sort of two-diverter design.
Here's the design.
Here's the parts list, all Hansgrohe:
I'd also appreciate any other comments or suggestions. In particular, is it better to run the overhead shower with copper or PEX? It's through an attic, so it seems PEX would be easier and more freeze-tolerant. The rest of the system is copper.
Jason
Here's the design.
Code:
Model # Component - Description
1850181 Valve Rough - iBox Universal Plus Rough with Service Stops, ¾"
4231000 Shower Valve - S Thermostatic Trim with Volume Control and Diverter
15984181 Diverter Valve - Rough, Trio 2-Way Diverter, ¾"
4232000 Diverter Trim - S Trio/Quattro Diverter Trim
14413001 Tub Spout - S Tub Spout
27458003 Wall Outlet - Wall Outlet with Check Valves
4266000 Slide Bar Hand Shower - Unica S Wallbar Set, 24"
27479000 Shower Pipe - Extension Pipe for Ceiling Mount
27381001 Overhead Shower - Raindance E 360 AIR 1-Jet Showerhead
Jason
