I'm installing an apron tub (kohler mariposa K-1229-R) that has flat area for the tub filler on both the apron side and wall side. The apron will be tiled, so it's not removable. I had decided I would mount the filler on the apron side, but now I'm having second thoughts.
Apron side:
Pro: easy to turn water on before getting into tub
Con: if it needs to be removed, only access is coming up through the basement ceiling with a long basin wrench.
Con: there's 3'6" of space at the head of the tub where someone can step in without stepping over the faucet, but if less mobile people who want to sit on the edge of the tub and then bring their legs across might have a harder time.
Wall side:
Pro: if maintenance is needed, can get full access by removing some drywall in the MBR (not ideal, but easier to repair than tile), or go through basement ceiling
Con: have to reach across the (3') tub to turn on water
I'd been leaning toward not wanting to reach across to turn it on, but am having second thoughts. I'm curious about experience here both from a use and from future maintenance perspective.
Thanks,
Bruce
Apron side:
Wall side:
Thanks,
Bruce
