Nicholas Meyers
Hello,
I am remodeling my master bathroom, but in the meantime got a ceiling leak this morning under what was the only other functioning bathroom's tub drain. So we're without a shower/tub.
Was hoping the experts on the forum could suggest what they'd do here.
The brass tube coming out of the shoe was badly corroded, and the shoe didn't line up with the vertical tee (which is parallel to the joist). The brass tube was under a lot of tension in order for the drain to mate with the tee, and probably accelerated the corrosion. It looks like they had some joist issues when they put it in.
I don't want to try to rotate the tee or replace the whole drain assembly because of access issues and besides the joist seems like it would prevent me from rotating the shoe as much as I'd need to.
I was thinking to put in a PVC shoe and run a horizontal PVC tube into the old brass tee with a slip nut. I am hoping that will allow some flex and compensate for the misalignment. For reference, I put a hammer in the drain opening in the last picture, but it's off laterally by about an inch.
Does this approach make sense? Should that give enough flex?
I was thinking I could also add a Fernco in the 5" horizontal tube to give some more flex. Or would that be too risky?
Thanks,
Nick
i
Thanks,
Nick
i
