ScottC543
Hello, all,
I need some advice. My tub drain was leaking. When I got it apart I found that when the tub was installed no gasket was used between the tub and the drain. The gap was filled with plumbers putty, which had dried and cracked, allowing the leak.
My problem is that the drain piping is concreted into the floor, and the gap between the piping seat and the tub isn't even. One side of the seat is maybe a quarter inch from the tub, while the other is nearly touching the tub. This leaves no gap to slide the gasket into place. I'm faced with having to completely pull the tub to get a gasket on the thing.
My question: Do I have any other options? Can a liquid gasket be used? RTV silicone, maybe?
I don't want to fix the leak in a way that will fail on down the road, as whoever came before me did. Pulling the tub will be quite the task, and I'd love to not go there.
A little help, please?
Thanks in advance.
Scott
Thanks in advance.
Scott
