Troubleshooting shallow well problem
Theonecloned
Minnesota
I'm having issues with a shallow well that I drove in last year. I drove 1-1/4 galvanized pipe with a stainless steel drive point. I drove it down with a weighted post driver and as expected the first 10 feet drove relatively easy. At around 12 feet the driving became very difficult. It wasn't a complete stop like hitting a big rock but progress was painfully slow. Every so often I would re-tighten the pipe then continue pounding. Eventually it started going a bit better and at 18 feet I hit water. From there the driving went much easier. At 25 feet I had about 7 feet of water in the pipe. I tested it with the pitcher pump and everything checked out. I connected things up and for the last year had no problems with it.
Then a few days ago I woke up and had no water but the pump was running. Not sure how long it ran dry but it was hot to the touch. After a couple attempts at priming I decided the pump was shot so bought a new pump. Once connected the new pump primed as it should and seemed fine most of the day. After sitting it lost prime so I started checking the obvious. I pulled everything from the pump to the pipe and cleaned the threads and used teflon tape and sealed everything up again. I have a brass check valve between the pump and the driven pipe which I cleaned when I had it off just in case and it seemed fine. One I had it all back together I was able to prime the pump and once again it seemed to be working fine. Unfortunately, I had no water again this morning.
My fear is that one of the connections below ground was damaged when driving the well. What are my best options? Before I do much I'm going buy another brass check valve to make sure nothing above ground is causing it to lose prime. I have my doubts though.
Would running a 1" black plastic pipe down to the point and sealing it on the topside be a workable long term option or should I consider pulling the point up and start over with a new point and pipe?
Any advice will be greatly appreciated. Thanks.
That much pounding probably messed up the threads. Might try the pitcher pump again and see if it holds a suction.
Thanks for the suggestion. I put the pitcher pump on and primed it. I left it for a about a half hour and it bled down a bit.
I was worried that the pounding was going to mess something up but hoped I had gotten lucky. I got almost a year out of it.
I can pretty much guess what's going to happen if I try pulling the whole works up. I'm guessing it the threads were damaged from driving it down they won't hold strong enough to pull it up and out. I'll probably run a 1" plastic pipe down and get by with it that way until I come up with a better game plan.
Is it worth trying to pull this out up or should I just pick a spot a few feet away and drive a new point and pipe and just cap this one?
As hard as it was to drive, I would try to pull the old one and use the same hole.
This is for sure the best plan but I should have a backup plan ready just in case the threads let go on the way up and leave me with a couple sections of pipe and a point deep out of reach.
Thanks for the advice.
