NIFARON
NIFARON
Hello all! Looking for some guidance! Sorry, this is a little long, but I've been chasing this for a bit now -
Summary: Is my GPM extremely low, or is this to be expected?
We bought an acreage with a deep well that had the pump replaced 2 years ago by a local plumbing company. They installed a 3/4 HP Little Giant model W12G07S9-22S - 12 GPM.
My current flow at a hydrant is ~2.5 GPM at very little pressure... sotra just trickles. Never builds up enough pressure to kick the pressure switch off. Just runs until the power is cut at the breaker. It's been this way since we bought the place a year ago.
First I isolated the well head from the pressure switch, tank, hydrants, etc - hooked a hose straight to the well head - still about 2.5 GPM.
So I pulled the pump tonight - photos here: https://www.facebook.com/nifaron/posts/10155760966188814
After pulling the pump up about 10' I tested once again (wondering if it was too low), same GPM.
After pulling it all the way out and laying the pipe across the ground I put it in a stock tank and it will output about 10 GPM pushing thru 160' of 1" line.
The depth of the well overall is 192 ft, the water is 102 ft down from the head, and the pump was hanging about 160 ft from the head.
The pump is 3.9" across, and the well casing ID is just over 4" - is this too small?
Pump is 2 wire 220 VAC - voltage reads fine on both sides of the pressure switch.
Thanks very much!
Aaron
Thanks very much!
Aaron
