astrila
Can anyone recommend a tank or a solution for this? We have a large indoor tank water heater hooked to a large jacuzzi tub and bathroom. It’s 20 years old and when we bought our house and did the home inspection the inspector recommended replacing it. It’s a 65 gal (71 capacity) and the size just barely fills the large tub so we can’t go smaller. Its location is in a walk-in closet on the 2nd floor.
So the only one Home Depot has in this size is a hybrid tank. I just called to buy it and have it installed, but the guy said hybrid tanks have to be installed in a garage or basement type spot, a cool location, they won’t install in an indoor closet. Smaller tanks won’t do the job, now I’m like... what now? How do we replace this thing?? He said we could add a mixer on to a smaller tank, but we really don’t want any decrease in temp at all because the jacuzzi already cools off fast with the bubbles etc. Tankless also won’t work, we don’t have the necessary electrical capacity.
I then checked with Lowes and they have an 80 gal electric tank which would fit... but it only comes with a 3 yr warranty and doesn’t look nearly as high quality as the one we currently have... although it does say designed for commercial use...but it seems to be the only choice anyway? It’s an “American Water Heater” brand. The one we have now, a GE, is already 20 years old and can’t last forever... But should I actually wait for it to actually really breakdown then before going for this less-than-ideal replacement that only comes with a lousy 3 yr warranty?... We do have a leak-system set up so if it did start leaking it goes outside... Or is there anywhere else that sells water heaters I should look into? I also see the 80 gal Geosprings Hybrid available online has an option to run in electric-only mode... Would that be a better option than the 3 yr one?
