I'll be needing a new natural gas water heater, due to installation of an 85 gallon whirlpool/spa bathtub. I'd love to hear your opinions about four alternative models which I'm looking at. There are two "special factors" at my location, which might effect your recommendations:
1) altitude 5200 ft.
2) incredibly "gentle" water.
3) earthquake zone.
How gentle? The current WH is 21 years old, and the original anode still has plenty of metal left to sacrifice. No leakage or obvious problems, but the 40 BTUH burner and 50 gallon tank can't come even remotely close to filling the tub. In reality, I know that the efficiency and performance are also far below the even the inadequate labeled capabilities from 1987 (there's both age AND altitude factors). I've zeroed in on two "normal" choices and two of the brand new condensing models. The water is from Lake Tahoe, down the Truckee river into Reno, Nevada -- so I don't have to meet California requirements, but I'd prefer to do the environmental "right thing" if it cost over ten years likes appears to be only a little bit more. Here's my picks-- and please feel free to suggest something else, too, if there's another quality choice which I've left out:
Cheapest "Normal": BW "Through the Wall" powered exhaust with 2" foam insulation, BW model M-2-TW-75T6BN. But the air near the floor of my garage gets dirty when the wind blows, and through the Donner Pass/Truckee River valley the wind blows very hard very often. I can smell at least some level of blow-back from the current heater, but maybe it's all from the open vertical exhaust flue, with none happening at the burner intake. But I'm in love with our condensing furnace, and I'd like to insulate that entire portion of the garage as if it were conditioned space-- so I'm inclined to prefer the next one:
Costlier "Normal": BW closed combustion system, their model PDX2-75T6FBN. I wonder, would the the blower-managed intake spin faster to help with the altitude compensation? Even if it doesn't, this is probably not a lot more expensive.
Now for the two "Exotic" condensing models: At current natural gas prices, they'd probably only make economic sense if they last 15+ years, AND if natural gas prices increase. (They'll both qualify for the $1500 rebates, but all the extra costs come in "up front" in year one.) At current natgas rates and our moderate usage, I see only about $700-$120 savings per year with the condensing models at current rates. But the much lower output in the "normal" model burners can barely meet our actual needs at Sea Level, and could lead to unpleasant issues in the future if their recovery rate falls with age. (I.e., the showers following drainage of the "happy" bath could turn nasty cold, partway through, if later owners make a sensible upgrade to natgas appliances for either the clothes dryer or kitchen appliances at later time.) 100 gallon HW storage tanks would require major remodeling, and that get's into a homeowner's association wrangle. I am not considering tankless, use of dual 50 gal/60gal/75 gallon gas heaters would cut into one of the garage vehicle parking spaces. But both of these condensing water heaters seems to have vastly greater recovery capabilities than we'll ever need, providing tons of "extra headroom", and definitely do it all with just a single unit.
First up is the very new BW EFR-1-60T1206EN. It advertises automatic compensation for combustion air changes. (As in, HIGH ALTITUDE. ) . It's a downflow burner; and their usual ceramic-lined steel is used for both the water side of the tank and the exhaust/condensation side of the condensing transfer coil. But it's larger than we need, in every way: Tank size is 60 gallons, and the smallest burner is 120KBTUH, and recovery with 90F rise is rated at 154 gallons per hour. The second rebate-qualified condensing natgas model I'm looking at is the American 'Polaris', model PG1034-1002NV. The "fit" is better: The storage tank size is only 34 gallons, even though we can easily get by with just the smallest of the 3 burners which they offer on this tank, just 100KBTU per Hour. (They do offer 130KBTUH and 150KBTUH on the same small tank, with the same 10-year warranty. That gives me some extra confidence in the 'Polaris' Stainless Steel tank, even though it might not really last any longer than Bradford-White's... the higher cost of more warranty failures could just be built into the cost of the unit.) The 100KBTUH burner is rated at a recovery rate of 130 GPH with 90F rise. Less, but more than I need-- and the smaller tank, which uses pretty much identical insulation as the Bradford-White, would probably have lower energy storage loss, too.
The Polaris burns upwards, and then the condensation coil curls back down, drains at the bottom. It burns upwards. Although the BW model has gone through several model revisions, it seems that the current versions of both products use very similar steel-mesh burners to spread out the heat, and to assist with more complete combustion. That's not an area of difference between the two models, even though the BW fires downwards into an upwards-looping condensation loop. The BIG differences which I see are the tank/burner sizes, the tank construction, and the fixed versus variable air/gas ratio. The American tank is 444 stainless steel, and their ten-year warranty (included even with a burner 50% more powerful than the one I would choose) is impressive. The BW has another minor thing which I don't like in the electronics: It uses a single PCB for both high voltage ignition and low voltage control functions. I've had a similar Honeywell single-PCB design burn out on my EAC, wiping costly controls when a high-voltage resistor fried-- but it's not a decision criterion. I wouldn't go crazy over replacing a single, more costly board which does nearly everything except the temp Sensor.
Here's the important question, I think: In real life, ignoring the warranty, is the lifespan of 444 stainless likely to beat the lifespan of the BW "Vitraglas" lining? In both cases, I suspect that fatal corrosion would occur from the exhaust flue condensate side first, rather than the hot water side. And is the Vitraglass tank likely to crack during a strong (but not overwhelming) earthquake, which is maybe 20-30% likely in this time frame? I would not be surprised to experience a 4.0-5.0 event in my neighborhood at some time during the next 20 years, and the flexible stainless tank might survive that. There was a 4.1 back in February, about 10 miles away, and some books did fall off of shelves here. (All the valuable stuff is anchored.) It was probably only about 3.0-3.3 within my neighborhood, but I have a closer fault which wasn't involved and didn't slip -- THIS time. ) Complex shock mounting could protect the Bradford-White unit too, but that adds a lot of $$$. I'd prefer to use just the earthquake straps and flex gas intake which code actually requires, they're cheap. My 50ft+ of iron gas supply line supply can run both the water heater and the furnace. (Kitchen an laundry are all-electric, because my DW has environmental sensitivities which preclude gas appliances within the living space. The fancy clothes washer has an electric heating element of its own.)
I have no idea whether the BW condensing heater costs a lot less than the American's Stainless steel, or whether the Polaris could be ordered with a different venturi/manifold combination to match the altitude better. If you know, please advise. In both cases, based on the current heater's incredible lifespan and anode condition, I'll SWAG that tank failure will occur from the exhaust condensate side (rather than the hot water side).
We are not planning to sell this house in less than 20 years. So, I'd like to know if you guys think I'd be happier, in the extremely long term, with a "traditional" for now (upgraded only when energy costs and rebate policies make it necessary); or the BW "Ultra" ceramic-lined condensing model, slightly bigger and more capable than I need; or the stainless steel Polaris.
I will hire out the install, I'm not licensed for natgas. My sincere, grateful thanks to all advisors -- in advance.
3) earthquake zone.
