Geoffrey Leach
- Messages
- 1
- Reaction score
- 0
- Points
- 1
This is a 13 year old Toto Ultramax 1 CST 854. After replacing the fill valve and flapper with Toto-branded parts, the tank level drops slowly until the valve kicks in and refills the tank. The drop is about 1".
What may be related, there is a sometimes-associated noise in piping that is about 15 feet upstream; tick-tick-.... sounds like a valve opening/closing, except that there is no valve. The toilet is the last connection of the branch.
I've put coloring in the tank to check if there is a leak into the bowl. No luck.
Water pressure is 60-40 with a pressure tank. There's a Takagi tankless water heater in the circuit. It is not running when the problem occurs.
