We have what was originally an Ultimate, purchased ~15 years ago, that's had its valve and flapper replaced with the Gmax versions over the years.
Most recently, the valve started leaking instead of fully shutting off. This was a TSU18A from 2012 (I started ordering parts online before they were widely available at HD/Lowe's, and it's a great help knowing exactly what I bought years later). The flapper had been replaced in late 2016 with a Korky 2021BP.
TSU18A fill valve
TSU99A.X
The valve I installed a few weeks ago is a TSU99A.X. I went by the directions, which, IIRC, had me set the height to 4 notches exposed and the throttling valve on the overflow tube to a 5 on the shim key that came with the valve. The only thing I'd do differently is that I cut the tube a hair short (maybe 1/8" to 1/4") and it bends a little at the overflow tube connection. It isn't kinked, but the tube gets a touch oval-y there. The hardest part was looking up the model number to be able to read the table with the settings for the universal valve.
So, here's what's happening. Unless you hold the flapper open, it closes too quickly and the toilet doesn't flush completely. Same flapper that worked fine with the old valve a few weeks ago. In typical fashion for my experience with Toto tech support, I called and their response was "it's your water" and they suggested replacing the flapper b/c it had become waterlogged. FWIW, I'm in Atlanta and our water is pretty soft and no chloramines in use. And this flapper has only been in the tank for ~18 months.
Suggestions? I have another valve on order to have as a shelf spare, and I'm going to open it up and make sure that the settings I used are correct. I've thought about raising the valve height by a notch, even though where I set it seemed to be per the directions and the same (as best I could tell) as the one I replaced. Seems pretty dumb to replace the valve and think that suddenly make the flapper not work. Thanks!
TSU18A fill valve
TSU99A.X
