GreenScrew
Having a hard time figuring out if I can find a Toto, was leaning towards the Drake/Drake II models, with the following specs:
Elongated bowl
Ada height
CEFIONTECT finish
Insulated tank
Preferably tornado flush.
I don't really care if it's 1.6 vs 1.28 flush, in some regards would almost prefer 1.6 as low flow seems to get a bad reputation in our parts for leading to septic issues in the winter (freezing). The biggest challenge seems to be the insulated tank in conjunction with the list of other requirements. Toilets will be installed at a lake home where we do a lot of entertaining and sweating is problematic when entertaining large groups as we often do. The insulated tank is ideal/preferred but I guess there is another alternative for using a mixing valve to warm the water? Anyone know if I can specify a model with these options and/or comment on the mixing valve alternative? TIA!
Elongated bowl
Ada height
CEFIONTECT finish
Insulated tank
